Unconfigures monitoring for each member port of a health check LAG.
port |
Specifies the member port. |
IP Address |
Specifies the IP address. |
TCP Port |
Specifies the TCP port. |
N/A.
Use this command to remove the monitoring configuration on the ports of a health check link aggregation group. Each port must be unconfigured separately, specifying the IP address and TCP port.
The following command removes the configuration setting on port 12 that monitors IP address 10.1.1.3:
# configure sharing health-check member-port 12 delete track-tcp 10.1.1.3
This command was first available in ExtremeXOS 12.1.3.
